Adding Picture to programs
If you do it with autorun you can give your program a picture.
Load in the inspection. Drag the window bigger and right click on it.
Now there should be something about iconic characteristics (Sorry i use Calypso in german)
There you can change the filling and set a picture for your program. So if the worker loads the arn he will se the picture.
If better explanation needed i can make some screenshots.
With the "User-definable measurement run info for CNC start" you can use the ZEISS Viewer, but beware of too big pictures: this program does not reduce!
For instance, if your resolution is 1024x768 and your picture is 1920x1080 you will see a zoomed picture instead of a resized picture that fits on your screen. Unfortunately, it fills the whole screen including the Windows tool bar.
But there are also two places where you are able to change the pictures:
1. The Calypso splash screen, there are 48x48 or resized screenshots by the offline planner. Name: preview.jpg
2. CNC-Start/Start Measurement, the picture above the selection in the upper left, it should be 94x128 to be shown properly. Name: icon.bmp
Just add the files to your program directory with the inspection file.
  • 2 weeks later...
