Degrees/Degrees Minutes Seconds
Yeah, you don't have any options when it comes to degrees, it's either Degrees decimal or DMS for everything.
I believe you could use a result element or PCM.
You'd have to convert the initial result from radians to degree decimal and then to DMS.
Somebody more fluent on PCM than I would have to give you the formula.
