Plot - Changing Default Plane?
Just wondering if anyone has any idea if the default plane for a line profile plot can be changed on a characteristic by characteristic basis in piWeb?
I have several 3D curves that I am using piWeb to display and unfortunately it seems like it always shows them from the wrong side and so far I cannot seem to figure out a method to change the default plane.
I can change the display plane inside the characteristic, but it defaults back to the original whenever it is re-opened.
It seems silly to expect the user to modify the settings every time they view the plot.
  • 9 months later...
At the moment there is only one way to change settings inside PiWeb templates, a customized templated must be used.
The settings only stored inside the template, when modified by the PiWeb Editor.
Only the magnification (not all graphic) and the style (2d or linear) can be selected by CALYPSO.
This is different to the old GraphicElement. Modifications was stored inside the inspection and used later for output (... Single Template settings) of GraphicElement menue.
I've to shift some customer to PiWeb and therefore create such "customized" templates.
Please look at other PiWeb posts, maybe it solves the requirement.
