[Me...] Posted May 1, 2019 Share Posted May 1, 2019 Need help offsetting a line or a point. I only see plane offset. ❓ any help will be appreciated. Thanks Link to comment Share on other sites More sharing options...
[Mi...] Posted May 2, 2019 Share Posted May 2, 2019 I add a point, switch it to a "theoretical feature", then populate the x-, y- and z-value boxes with formulas tying them to the point I originally probed. If the direction of the offset isn't parallel to any of the base alignment axes, I suggest defining an additional alignment in the appropriate direction to make it easier. That probably didn't make much sense, but if you have a specific example I might be able to explain more clearly. Link to comment Share on other sites More sharing options...
[Me...] Posted May 2, 2019 Author Share Posted May 2, 2019 Thanks, I'll try that Link to comment Share on other sites More sharing options...
