[Cl...] Posted April 26, 2019 Share Posted April 26, 2019 What does "Anglet" mean in the true position output. Engineer is suspicious about this? Po2d Anglet -117.35431 X -0.10019 Y -0.00037 Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/ Share on other sites More sharing options...
[De...] Posted April 26, 2019 Share Posted April 26, 2019 From a quick internet search anglet is german for corner. So my guess is its simply poor translation. *Shocking* I know. It should be simple enough to calculate what this actually is based on whatever you are measuring. I would expect this to be the angle between a line along the positive X axis and a line from the center of the coordinate system through the center of the hole. The center of the coordinate system would probably be the center of the pattern of holes assuming this is a pattern of holes. Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/#findComment-105500 Share on other sites More sharing options...
[An...] Posted April 26, 2019 Share Posted April 26, 2019 Please sign in to view this quote. No! See attached.Contribution_26_04_2019_a.xlsx Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/#findComment-105502 Share on other sites More sharing options...
[De...] Posted April 26, 2019 Share Posted April 26, 2019 To clarify .. what I meant was Corner == Bad Translation of Angle So anglet should say angle ... which is what you are calculating no? Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/#findComment-105504 Share on other sites More sharing options...
[An...] Posted April 27, 2019 Share Posted April 27, 2019 Yes,it's the missing blank! Still not an employee of the ZEISS Company. See attachedContribution_27_04_2019.pdf Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/#findComment-105506 Share on other sites More sharing options...
[Cl...] Posted April 30, 2019 Author Share Posted April 30, 2019 What answer am I missing here? I opened your spreadsheets and still do not know what "Anglet" refers to? Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/#findComment-105508 Share on other sites More sharing options...
[Ma...] Posted April 30, 2019 Share Posted April 30, 2019 Clark If you create a triangle using Y1 and Z1 in his example then 3.1471 is the angle of the triangle. Andreas was pointing out that it should read Angle T1 instead it reads Anglet1 Mark Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/#findComment-105510 Share on other sites More sharing options...
[De...] Posted April 30, 2019 Share Posted April 30, 2019 By this logic is it Heigh t1 as well? Regardless how many hairs you want to split, they screwed up the output on the report but it is not really a big deal. You have height, angle, and your two position values. You can use the values to prove this as Andreas has in his spreadsheet. Link to comment https://qualityforum.zeiss.com/topic/18738-anglet/#findComment-105512 Share on other sites More sharing options...
