[Ri...] Posted April 29, 2019 Share Posted April 29, 2019 This version is getting ugly. With issues iv'e read about 2018, were holding off (damn right I'm skeered). 1st problem, PiWeb. A pain in the Ace. Forced to use it because the better (My opinion) reporting method is going away. Calypso creates results that are all in tolerance (some high limit, some low limit) and PiWeb creates a report that some things are out of tolerance. And to top it off, PiWeb adds tolerance to Coordinates from True Positions and Profiles. TOLERANCES! 2nd problem, Planar is Slow like molasses in Alaska. viewtopic.php?f=13&t=1396 A fix is provided that appears to work. Annnddd then it doesn't work. 3rd problem, once the fix quits working, now I have a model that jumps all over the screens universe when selecting entities (I like to call it the Calypso Way....Milky Way....and no laughter...tough crowd). I just started getting that issue today. viewtopic.php?f=13&t=1503 4th problem, existing from v6.0.x, an actual bug I discovered. When working with Solid Works models, if you use "Display all CAD features in CAD View", POOF! The model is upwards of 40 million inches away (That's not a typo boys an girls). We have v15 and v17. 5th problem, it seems now that its 50/50 whether or not the correct Clearance plane is selected when creating an entity from a model, 50% of the time, its all Z axis. If I dug into this forum I could probably find more info that would trump, Trumps Tweets (Not even a giggle 🙄 ). Since this upgrade, that's an oxymoron, I spend a good deal of time correcting these issues, except for the 2nd Problem, can't fix that one. Almost forgot this one. When using the new Caliper tool. See image "System Error.jpg". Seems Caliper cant handle changing features to generate a result. Please sign in to view this quote. Rant over.System Error.jpg Link to comment https://qualityforum.zeiss.com/topic/18740-2017-v64xx-bugs-are-just-stacking-up/ Share on other sites More sharing options...
