Service Pack 6.6.1601
Anyone having issues with the new Service pack and the offline seat?
It seems to be having issues with the solid model when using saving as the model disappears.
Also I can't change styli from the drop down on the tool bar, I can only them in the Probe System Qualification window. If this is happening on the CMM PC with an RDS head then that is really, really bad because that OK button in the Probe System Qualification window makes the active stylus the "favorite" and will rotated to that stylus before rotating to the one you need at the RACK!
If I find any more I will update this post, I just started writing some programs and less then 5 minutes into it I ran it to these 2 issues.
