[Ja...] Posted April 18, 2019 Share Posted April 18, 2019 I am running into this error message at the end of my program run. I am writing a program for a cylindrical shaped multi pin connector contact block. I have wrote several programs for similar connector blocks with the only difference being this one has a small tab with a radius at the tip that is a datum. I am creating a circle at the end of the tab(See attachment) and using this for my base alignment without any issues until the end when trying to calculate the True Positions. I have used the tabs as base alignments in the past on similar connector blocks without any issues. The only difference being I had larger side walls for the tab and was able to create a symmetry plane between the two vertical planes and use that for a datum in the base alignment. Any ideas of another way to use the tab in my base alignment? Thanks in advance! JarrodWrong plane for plane correction error message.docx Link to comment https://qualityforum.zeiss.com/topic/18780-wrong-plane-for-plane-correction-error-message/ Share on other sites More sharing options...
[Da...] Posted April 19, 2019 Share Posted April 19, 2019 Post a screenshot of the error and snip from the drawing regarding the true positions. Link to comment https://qualityforum.zeiss.com/topic/18780-wrong-plane-for-plane-correction-error-message/#findComment-105712 Share on other sites More sharing options...
