CMM-Number
I just installed 6.6 on a couple of my Sheffield retrofitted machines, and noticed that CMM-Number is 000000000000. Is it possible to change that, and if so, where do I need to go, in order to change it?
Hello,
the CMM-No is stored normally inside the Controller
> Zeiss-Controller
CZIMT-Service
> I++ Connection
Service installed the I++ connetion may know it
Software-Support CALYPSO told me there is no file inside CALYPSO with CMM-No.
Klaus-Dieter
All of our CMM's show the last six digits of the serial number.
There is also a PCM parameter that can recall the CMM serial number.
 getRecordHead("dmesn")
If its set to 000000 in your machine tab settings you wont get any thing else then 000000 back with dmesn.
But you could try cmmInquire("sfmt(#cmm Number)") to see if something else is stored on your controller.
