[Me...] Posted April 16, 2019 Share Posted April 16, 2019 Hi, I have a Zeiss Duramax 5/5/5 I'm having a problem, currently running Calypso version 5.4 from the nothing the software won't boot up, I start it and it shows the image and says "Dmax: Initializing" but it locks on that message and won't open anything, it also show an scheme ACIS interface driver extension window that says "not found" what can it be ? Thank for your attention Link to comment Share on other sites More sharing options...
[Br...] Posted April 16, 2019 Share Posted April 16, 2019 I would try first restarting your computer. If that doesn't work, make sure you have the latest service pack. If all else fails, you might need to give Zeiss a call. Link to comment Share on other sites More sharing options...
[No...] Posted April 16, 2019 Share Posted April 16, 2019 Error messages in the ACIS window CAN be relevant, but many of them are not. Can you post the exact message? What is it that's not found? There are many possible reasons, ranging from install errors over damaged files to access rights. Link to comment Share on other sites More sharing options...
[Me...] Posted April 16, 2019 Author Share Posted April 16, 2019 First of all thank you for the fast reply. The message that appears is this Calypso gets stuck in these window and doesn't open Link to comment Share on other sites More sharing options...
[No...] Posted April 17, 2019 Share Posted April 17, 2019 That's one of the irrelevant messages. It appears every time, even if the machine is working fine. The ACIS process controls Calypso's CAD window. If Calypso want's to display or change something in the CAD window it sends a command to the ACIS process. So all error messages in this window are only CAD related. You can safely ignore ACIS messages as long as there are no CAd-related problems. Link to comment Share on other sites More sharing options...
