[Ty...] Posted April 11, 2019 Share Posted April 11, 2019 Might be a long shot, but is anybody familiar with Calypso 4.0? We are trying to work with a new supplier that only has Calypso 4.0 and they are saying the only way to export results is through a screen shot. Our preferred method is a txt file. Does anybody know how to do this, or what other export methods Calypso 4.0 has. Link to comment Share on other sites More sharing options...
[Ro...] Posted April 12, 2019 Share Posted April 12, 2019 Aahh boy..... Do they have PCM? Link to comment Share on other sites More sharing options...
[Th...] Posted April 12, 2019 Share Posted April 12, 2019 Hello Tyler, Calypso 4.0 had also the ability to export results in different ways as actual versions do. Without PiWeb, which came later, it is able to use Q-DAS (License needed), PDF or simply the compact or default printouts. The last two printouts can be copied and saved to TXT. (They are not as beautiful as the custom printout but bear more information.) And the whole measurement program can be set with compatibility mode down to version >=3.4 so it could be used with older Calypso versions - if you are considering to give the program away. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 12, 2019 Share Posted April 12, 2019 I started programming around 4.10, but I thought that the Excel exporting has been there way before that. I could be mistaken. You should be able to do an ASCII text file export. Link to comment Share on other sites More sharing options...
[Ow...] Posted April 12, 2019 Share Posted April 12, 2019 See attached excel spreadsheet used to convert Calypso table files into editable data. It's 15 year's old, no guarantees.Calypso_dataread3.6.xls Link to comment Share on other sites More sharing options...
[Ow...] Posted April 12, 2019 Share Posted April 12, 2019 oh_ and here's an old instruction document proving Calypso was capable of reporting to excel in as early as 2000, which was way before Calypso 4.0. Version 3.6 was used in 2004.old_Calypso and Excel Reporting.docx Link to comment Share on other sites More sharing options...
