Decimal Places on print out
The printout has its own settings, if you are using the pi web report go to the measurement tab and click multiple printout. Then click the little pencil by the format. it will open up your piweb template editor, then under the tools tab go to settings. Under general there you will see the decimal places.
Resources...Characteristics settings editor...Units (from the drop down menu)...number of decimal places...selected features.
Then select what characteristics you would like to change. Here you can individually set them for this measurement plan only.
