[Cl...] Posted April 3, 2019 Share Posted April 3, 2019 I need to create a batch file to pull the .chr/.hdr/.fet files from the results folder to our network drive. Any assistance on this would be greatly appreciated. Link to comment Share on other sites More sharing options...
[Er...] Posted April 3, 2019 Share Posted April 3, 2019 MOVE "C:\PATH\FILE.EXT" "N:\PATH\" You can use wildcards as * or ? to move several files or random named files. Hum, giving it a second tought. Is your network stable? There are more robust solutions with robocopy, but usually it's not nessecairly to control the integrety (not 100% sure of the word, not a yank or brit) of the moved files. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 3, 2019 Author Share Posted April 3, 2019 So, just insert that text into note-pad, and save it as a .bat file? Then insert it into the program folder? MOVE "C:\PATH\FILE.EXT" "N:\PATH" Link to comment Share on other sites More sharing options...
[Er...] Posted April 3, 2019 Share Posted April 3, 2019 You need to change the paths to suit your needs. But yes. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 3, 2019 Author Share Posted April 3, 2019 As simple as this, or am I missing something? I had to resave it as a .txt file to attach here. Link to comment Share on other sites More sharing options...
[Er...] Posted April 4, 2019 Share Posted April 4, 2019 You forgot two double quotes. (If that path contains space it will end up doing something else then your intent.) Move "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\chr.txt" "T:\DMR\CMM Data\0934_Data\merge_chr.txt" Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 Tack! Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 I'm doing something wrong. Link to comment Share on other sites More sharing options...
[Re...] Posted April 4, 2019 Share Posted April 4, 2019 Try this ! Copy "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\*chr.txt" "T:\DMR\CMM Data\0934_Data\*chr.txt" Copy "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\*hdr.txt" "T:\DMR\CMM Data\0934_Data\*hdr.txt" As Eric wrote: " You can use wildcards as * " Link to comment Share on other sites More sharing options...
[Er...] Posted April 4, 2019 Share Posted April 4, 2019 Unless Calypso overwrite previous table files that might not give you a satisfying result when your spc program keeps reading old files over and over hehehe 😃 But do what Reiner says, but change copy to move, or add the syntax del to your original files. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 Nope, nothing is being sent to the folder. Thanks anyway. Link to comment Share on other sites More sharing options...
[Ja...] Posted April 4, 2019 Share Posted April 4, 2019 Are you looking to create a copy in the network folder or send results there? Try: Resources --> Name for output files This will allow you to set the directory and output names. You will need to do this for each of the 3 types. You can set for current plan or globally. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 Unfortunately that field is currently being used to save a compact report: "T:\DMR\CMM Data\100292 Op-10_Rev_B\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt" Unless I can enter multiple lines of the above type code, which I'm guessing I can't? Thank you everyone for all the help. I really appreciate it. It's just not working. My next stop is Zeiss support. Link to comment Share on other sites More sharing options...
[Ja...] Posted April 4, 2019 Share Posted April 4, 2019 I was able to enter multiple lines when I tested. Select the Output type in the dropdown box and check the "Name of output file variable" box. Repeat for each file type. This will add each to the box at the bottom and then you can edit the output path and file name. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 Thanks Jason, I'll give that a try after lunch. Link to comment Share on other sites More sharing options...
[Er...] Posted April 4, 2019 Share Posted April 4, 2019 There are three possible errors. Either a typo, or you dont have write permission on the network location, or you are running unix. Open the start menu, search for cmd, start it. And type move /? And Compare the example to yours. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 I have permission, and not using unix. Typo it is! Don't know where it is though. Link to comment Share on other sites More sharing options...
[Er...] Posted April 4, 2019 Share Posted April 4, 2019 Post the content of your file and Ill see if I can spot it. A little "where waldo" 🙂 Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 Here's the .bat (txt file) with the path from - to. I had to change it to a .txt file in order to attach it. Move_0934.txt Also, here is how I have the table files set-upTable_Files.docxMove_0934.txt Link to comment Share on other sites More sharing options...
[Er...] Posted April 4, 2019 Share Posted April 4, 2019 Use this move "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\*chr.txt" "T:\DMR\CMM Data\0934_Data\" move "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\*hdr.txt" "T:\DMR\CMM Data\0934_Data\" You cant move or copy files to a wilcard name. Or move "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\*.txt" "T:\DMR\CMM Data\0934_Data\" If your "from" folder dont contain any more txt files that you dont wish to move. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 4, 2019 Author Share Posted April 4, 2019 Link to comment Share on other sites More sharing options...
