Unable to calculate alignment?
(SOLVED! THANKYOU) I am trying to create a base alignment for a extremely simple round part, but for whatever reason I keep getting:
"unable to create base alignment".
I tried using the Outside Diameter measured as a cylinder for my Spatial Reference and X-Y origin
Constructing a 2d line with the two holes highlighted here and using it as my Planar Rotation
and finally taking a point or plane off the top of the part for my Z-origin.
These three elements would be more than sufficient for any other CMM I've run, what does calypso want?
if I do create a 2d_line from two features is there a way to project it up to my top_plane?
For example measuring a circle, the default scan speed is 100, yet the cookbook says 5 is the max for passive scanning.
Richard, I think the reason it couldn't calculate was that the circle you tried to use for spatial alignment doesn't really work that way. you need a Cylinder or a plane to use spatial. ( a 3d line or cone also works ) A circle has only a center point, not an actual axis.
