Calypso to Datalyzer
Does anyone out there have experience with sending variable data from Calypso top Datalyzer?
We need to turn on and merge the table files inside one of our
programs, and send them to the network drive. Then use that
data in Datalyzer. I'm assuming this something that can only
be done using PCM?
I use something similar(Micronite) and have it draw my files from the results folder but it is a hastle to get IT to create the connections.
basically a vpn (Virtual Private Network)connection from the Micronite server to the results folder on each CMM. When Calypso sends the files to the results folder, Micronite collects the data and deletes the file from results folder when done with it. Not a lot of info but hopefully it can point you in the right direction
