2d Curve
Good morning all,
We're having issues holding a .002 profile so we've added stock to see if we can fine tune the cut on the machine in...
In order to account for the stock, under Modify Nominals/in vector direction, I added the amount of stock (per side) in the Translation area.
Is this a good way to do that?
Or you could just use a profile with a "unilateral tolerance outside" of .004, which would center the theoretical nominal at .002 plus material.
Unilateral tolerance of course is a profile with all the tolerance in 1 direction.
The hard part is remembering which direction the tolerance is going to be in, because the results will always be a positive number.
Think of Unilateral Outside as being outside of the cad model, or a heavy material condition. so outside profiles like the one you have will be the tolerance zone.
What calypso does is to offset the nominal, so in your instance where you're targeting .002" heavy, a tolerance zone of .004 would be +material.002 +/-.002.
Now if you wanted a bigger tolerance you'd have to go with Unilateral unequal distribution, and then the math gets funny, but zero will still be the center of the tolerance zone.
I used to have a PDF i believe was titled "ProfileCalls" but i can't find it now that i have a new pc in the past couple months.
I'm sure someone will have it and post it.
