[To...] Posted January 15, 2019 Share Posted January 15, 2019 I'd like to hear how some of you guy that deal with plastic molded parts. In particular, dealing with draft angles, which I understand is necessary for molding parts. For example, a cylindrical-ish part, on the X axis. The end face is a cone with a 178° included angle or 1° draft angle. This end face is Datum A for many of the GD&T Profile and True Position call outs on the part. If I extract the feature, it is a cone. In the Base Alignment or in the characteristics, do you guys use this cone as your spatial and X origin or Primary Datum, or do you create a plane and use it for for everything. I am considering using a 3d Best Fit Alignment for my Base Alignment. There are several cavities on the part that are using Surface Profile to ABC. Do prefer to use FreeForm and scan all-over or do you just use Space Points and Space Point Distances. I would lean towards Space Points due to time. I am considering even using Free Form but using touch point strategies. That way I get the benefit of tolerancing multiple face profiles and the speed of touch points. I'd really like hear what is "common" practice in the molding industry. Link to comment Share on other sites More sharing options...
[Da...] Posted March 21, 2019 Share Posted March 21, 2019 Tom, I can't get my head together to throw more info, but I want to warn you about using cone as primary in base alignment. It can/will cause trouble like turning things around occasionally. Link to comment Share on other sites More sharing options...
