Probe Rack
We bought a probe rack MSR mini and the right higher side we is too high for us to put probes in. We were thinking of cutting it down to get the space we needed. Has anyone done this and how did it work?
Are you saying the trunk of the tree is too tall? If so I just went and looked at mine...can-o-worms.
Those cam locks look to be a certain length. Study it carefully.
I've custom made a rack to be different from the original in the past.
As Kevin mentioned, make sure the cam-locks can still function within the grooves properly so the new arrangement is robust, shouldn't be a problem.
So Owen, how did you do it? You shorten the cam-lock rods or just re-drill the cam locations?
Kenneth if you do proceed with it, in my opinion, make sure you mill it parallel to the table.
