Unilateral tolerance in Result Element
How can I set the tolerance bar as unilateral from a result element feature?, I disable the lower tolerance in the feature but the report still shows bilateral tolerance bar: 1375_cad0a435c29ce4fc4199be114060e160.png
Hello Israel,
at the Moment there is only a Workaround possible
- Instead of "ResultElement" use "Form" to Report Curves
- If I have results with "Zero limited border" I put halve of actual into a Feature Point and use Position Tolerance.
I'm also missing the function "set Status to Zero limited".
Will save time and be much clearer.
regrads
Klaus
