[Is...] Posted March 12, 2019 Share Posted March 12, 2019 How can I set the tolerance bar as unilateral from a result element feature?, I disable the lower tolerance in the feature but the report still shows bilateral tolerance bar: Link to comment https://qualityforum.zeiss.com/topic/19056-unilateral-tolerance-in-result-element/ Share on other sites More sharing options...
[Kl...] Posted March 13, 2019 Share Posted March 13, 2019 Hello Israel, at the Moment there is only a Workaround possible - Instead of "ResultElement" use "Form" to Report Curves - If I have results with "Zero limited border" I put halve of actual into a Feature Point and use Position Tolerance. I'm also missing the function "set Status to Zero limited". Will save time and be much clearer. regrads Klaus Link to comment https://qualityforum.zeiss.com/topic/19056-unilateral-tolerance-in-result-element/#findComment-107272 Share on other sites More sharing options...
[Is...] Posted March 13, 2019 Author Share Posted March 13, 2019 Please sign in to view this quote. 😐 not nice solution, but works anyway, thanks Link to comment https://qualityforum.zeiss.com/topic/19056-unilateral-tolerance-in-result-element/#findComment-107274 Share on other sites More sharing options...
