Calypso really slow!
Hi,
My Calypso is super slow!!
I'm measuring parts based from our customers .stp files, which I convert to .sat
Currently I'm having a part, where everytime I press Charachters or Features, it takes about 10 seconds before it's done thinking.
Has anyone experienced the same? I have a concern about the file conversion, which I do by opening the .stp in Spaceclaim and save as .sat
Hope to get help on this so I don't have to use all week on this measuring program 🙂
Best Regards,
Johan
Pretty common issue.
I have my PC Maxed out with Ram and i still get this issue (although other issues have been fixed with lots of ram)
Whenever you click on a profile, Calypso will insist on recalculating and rethinking.
consider yourself lucky it's only 10 seconds.
Are the models your working with really large? That can cause a slow response.
I had a similar problem, so I got our IT department do transfer some of the larger
files from C to our network drive. That helped a lot!
When is the last time the PC has been shut down? Some time shut down and starting back up helps as it clears the temp memory out. On the PC at the CMM I would also clean out the Base Systems folder to help speed up Calypso.
