Profile
  • 2 weeks later...
The simplest way is to create an alignment that matches your DRF, put the Space Points in that alignment, and report the PtDist of each point. You may need to use a Best Fit alignment if the part has unconstrained DOF. You won't get mobility from any material boundaries on the datums. You can also Best Fit all the points in an alignment and use that if there are no datums, build features from them, etc.
