PCM stuff
A Collegue have had asked me to assign the actual shift by PCM.
My solution and other stuff.
Maybe someone save a little bit time.
// Activate Display
display("#displayCLOSE")
display("#displayON")
// Shift
// Start time input decimal
Shift_1 = 6.00 // time shift-1
Shift_2 = 14.00 // time shift-2
Shift_3 = 22.00 // time shift-3
pT = chr(9) // single tabulator into parameter
pT2 = chr(9)+chr(9) // double tabulator into parameter
StartRun = timeInSeconds() // time stamp start
//24 hour time format
HoursActual = int(StartRun/3600)
MinutesActual = int((StartRun-HoursActual*3600)/60)
SecondsActual = StartRun-HoursActual*3600-MinutesActual*60
StartTime = val(HoursActual)+"_"+val(MinutesActual)+"_"+val(SecondsActual)
//Assign Shift
//StartRun = 22*3600-1 // unmask for test
ShiftSecond_1 = Shift_1*3600
ShiftSecond_2 = Shift_2*3600
ShiftSecond_3 = Shift_3*3600
selectCase StartRun
case ShiftSecond_1 to ShiftSecond_2
ShiftActual = "Shift-1"
//display(ShiftActual)
case ShiftSecond_2 to ShiftSecond_3
ShiftActual = "Shift-2"
caseElse
ShiftActual = "Shift-3"
endSelect
//Output into display window
display(ShiftActual, pT2, getRecordHead("operator"), pT2, StartTime)
display()
// Assign record head, Protokollkopf Parameter
setRecordHead("shift", ShiftActual)
//Show ASCII char available inside PCM
//Display initialized
//display("#displayCLOSE") // unmask for single use
//display("#displayON")
for i = 1 to 256 // mask 3 lines to deactive it
display(i, chr(9), chr(26), chr(9), chr(i))
next i
Try this.
if (timeInSeconds() >0.0) and (timeInSeconds() <21600) then
SHIFT=3 //3rd shift between midnight and 6am
endif
if (timeInSeconds() >21600) and (timeInSeconds() <50400) then
SHIFT=1
endif
if (timeInSeconds() >50400) and (timeInSeconds() <79200) then
SHIFT=2
endif
if (timeInSeconds() >79200) and (timeInSeconds() <86400) then
SHIFT=3 //3rd shift between 10pm and midnight
endif
