Unilateral profile
I need to use unilateral profile. The profile is in the direction of the material only. I think I need to use "Unilateral (nominal contour inside)" on both of the profiles you see in my sketch. It is a ring shaped part. When you select nominal contour inside, it means in the direction of material right?
20190307142916359.pdf
Yes, if you just press F1 and search the keyword "Unilateral", you will find the definition for Unilateral (nominal contour inside) is "Nominal contour and distance to the inside"
