HELP :Accuracy of vast xxt and dt dyna touch heads
Hi guys,
Please can you help me with a problem : i am trying to find out what is the maxium lenght of a stylus that can be put on a stylus system and not lose accuracy.
I understand that the lenght of the stylus is different on the axys XYZ
I need some tehnical specifications on my VAST XXT and DT DYNA Touch heads
Can you help me guys with these info's ?
If you can find the case that the XXT body came in, there is a card that shows the length and weight limits of your XXT sensor. It depends on which TL version you have.
