how to Stop _hdr.txt Files and still use eXcel?
Okay,
How would one stop the _hdr.txt, _fet.txt, and _chr.txt. files. Still need excel report.
We have to delete them manually after the run.
Thanks!
Table files are created as part of generating Excel reports. I don't believe there is a method to delete them unless it is possible via the PCM option
If you turn off the table files, can you not still use the excel report template? Try it and see what happens. Go to Resources>results to file, and check the table files to "OFF". Then run a report using the calypso excel report template and see if it runs.
I use the inspection_start.bat file to remove the table files before each run. If you put this file in the "inspections" folder it will execute every time a you run a program.
Example file:
@ECHO OFF
C:
REM Location of your output files, usually in the following folder
CD C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results
DEL *hdr.txt
DEL *fet.txt
DEL *chr.txt
