Intersecting point dimension
Hey guys,
I would like to know if there is another method to inspecting a dimension as shown in the sketch I made. The dimension I am trying to measure is the .136-.160 Dimension. The way I did it is I created two planes on the angle dimension 49-51 Degrees, and created two planes on the .096-.098 Dimension and created a Symmetry between the two surfaces. Now I created a intersection between the two angle planes I created, and then added a third with the symmetry where it gives me the intersecting point. Then I just use Cartesian to get the measurement from the top plane to the intersection I created. The software is telling me it is oversize. I would like to know if there is another way to measure that feature, or the way I have describe is the best way.
Thanks.
Intersection.pngIntersection drawing.pdf
