Reports
Good Afternoon
So after I run a program and the report comes up is this saved somewhere or do I have to save it to a file. I have run a few programs I made so far and cannot find the reports.
If you are using PiWeb reporting you can send the results to pdf by selecting the pdf icon in the multiple printout window for the report.
If you are using the custom printout you can send the results to pdf by select pdf in Resources/Results to File
