PiWeb Stop Light Icons
Does anyone know if I can customize the stop light icons. I know there are different ones but I want to modify the smiley for yellow it is 🙂 when it should be 😐 or 😮 .
Way to happy for a part that needs to be modified. 🤣
  • 2 weeks later...
Hello Ted,
Here you would need to modify the element template, in this example the stoplight.
Open up your report designer where you can modify reports.
1. Double click on your stoplight or enter the "property grid" for the stoplight you want to modify.
2. Make sure the "Use Status images" button is checked
3. Select the image you wish to exchange
4. Select a different image from the available icons
or
5. Select a custom image from your PC.
TIP: Once this stoplight is modified, you can save this as an element template for later use by right clicking on the element and selecting "create element template". You will then find your modified stoplight in your toolbox.
I hope this helps!
Josh Smokovitz
Product Manager – ZEISS PiWeb
ZEISS Industrial Quality Solutions
steps 1-3.jpgFetching info...
