Auto Run desk Red Box
When I go to an older Auto Run Desk I sometimes find a red box around the program that I'm trying to run. I know that the red box means that the file path has changed, but can someone refresh my memory on how to change that file path.
Thanks,
Rachel
It is usually easier to just create the icon again for Measurement Plans, Pallets are easy to fix because can just edit and choose the program. If you want to replace it use Edit/Replace paths for Measurement Plans
If it's not a network drive, make sure that Windows has properly established the connection before opening AutoRun. You can go to windows explorer and click on the mapped network drive to force it to connect.
This may not be what you're talking about, but I've seen this before.
