[Cl...] Posted February 15, 2019 Share Posted February 15, 2019 I'm trying to install 2018 on my laptop. I get the attached error message. My IT dept. successfully loaded the Microsoft SQL server that is one of the requirement's for 6.6, but Calypso still won't install. Anyone else having this problem? Link to comment Share on other sites More sharing options...
[No...] Posted February 15, 2019 Share Posted February 15, 2019 I don't have the problem, but a guess: Maybe the installer doesn't check whether the SQL server is installed, but just if the required install files are present. And that is either not the case or there are access problems at the destination directory. Just a guess. Have you tried redownloading the install file? Sure you have. Have you? 😉 Link to comment Share on other sites More sharing options...
