[Fl...] Posted February 14, 2019 Share Posted February 14, 2019 Hello friends, I have. Questions? I cant see the report of the measurment in real time ,not after the complet measurment îs finish???thanks Link to comment Share on other sites More sharing options...
[To...] Posted February 14, 2019 Share Posted February 14, 2019 Unfortunately, this is how it works. If you want to see results as they run, you'll need to use the Default Printout. However, live output from DP is not on by default. Go to Resources - Define Printout - Click on the Default Printout tab at top. Un-tick "Background". Now, when you run, the DP will auto-populate results as the program runs. If you run from Features list, the DP will show data from all of the features first, then all of the characteristics. If you run from Characteristics list, it will show the first feature's data, followed by the first characteristic data. Link to comment Share on other sites More sharing options...
[Fl...] Posted February 14, 2019 Author Share Posted February 14, 2019 Thanks.thx Link to comment Share on other sites More sharing options...
