[Ty...] Posted February 2, 2019 Share Posted February 2, 2019 What is everybody's recommended Evaluation Method for Flatness? The program I am running now was set up as Minimum feature and I'm getting a result of 0.06mm. If I change that to LSQ, my reading jumps to 0.09mm. I think I understand why they are different, but I didn't expect a 50% jump and thought it would measure better. Just wondering what everybody else uses and why? In case it matters, this is a Flatness Ref with a Zone Size of 100x100. Link to comment https://qualityforum.zeiss.com/topic/19336-recommened-evaluation-method-for-flatness/ Share on other sites More sharing options...
[Me...] Posted February 2, 2019 Share Posted February 2, 2019 Use Minimum Feature (Minimum Zone). "Minimum-Zone fit yields a lower (or equal) peak-to-valley distance of the residuals and can be a better indicator of form, particularly if the data points are “good”, meaning fairly dense, with no outliers, and not much affected by measurement noise" Link to comment https://qualityforum.zeiss.com/topic/19336-recommened-evaluation-method-for-flatness/#findComment-108772 Share on other sites More sharing options...
[Da...] Posted February 4, 2019 Share Posted February 4, 2019 Are you using evaluation and speed from the cookbook ? It should be speed 3mm/s with 3mm probe. and step width 0.31/ factor for outlier 3.0 / adjacent points 5 / No. of iterations 1 / wavelength 10mm / Filter 2.5 I am using LSQ Link to comment https://qualityforum.zeiss.com/topic/19336-recommened-evaluation-method-for-flatness/#findComment-108774 Share on other sites More sharing options...
[Er...] Posted February 4, 2019 Share Posted February 4, 2019 Please sign in to view this quote. is a very brave statement. It all comes down to the surface properties of that unique surface. Is it polished, milled, turned. Ra, Rz or Rp limitations? Or any surface requirements? The cookbook is a merely a starting point, not the final solution. Link to comment https://qualityforum.zeiss.com/topic/19336-recommened-evaluation-method-for-flatness/#findComment-108776 Share on other sites More sharing options...
[Ri...] Posted February 4, 2019 Share Posted February 4, 2019 All form measurements should use Minimum Zone which is the default when you create the characteristic. Link to comment https://qualityforum.zeiss.com/topic/19336-recommened-evaluation-method-for-flatness/#findComment-108778 Share on other sites More sharing options...
[He...] Posted February 7, 2019 Share Posted February 7, 2019 Please sign in to view this quote. And thank god for that. I always gets very nervous when Germans speak of the "final solution". Link to comment https://qualityforum.zeiss.com/topic/19336-recommened-evaluation-method-for-flatness/#findComment-108780 Share on other sites More sharing options...
[Er...] Posted February 7, 2019 Share Posted February 7, 2019 Hehe yeah.. I actually chosed those words to see if anyone would react, and you sir, you never dissapont me. Not to spin away from the topic, but I scrolled through the presentation of 100 years of metrology. Seems like no innovations beween1926 to 1953, sounds highly unlikely, like nothing happend at all. 😱 Link to comment https://qualityforum.zeiss.com/topic/19336-recommened-evaluation-method-for-flatness/#findComment-108782 Share on other sites More sharing options...
