Manual probe set without dock station
Hello. I was wondering if I can use stylus system without dock station ? I am using DuraMax and I have 9 dock station and all are fixed probes that I cannot changed. Is it possible to write a program that in the middle of the program current stylus goes away and operator will put the special stylus system manually ?
If the program calls for a stylus system that isn't assigned to a holder in the rack, it will give a warning message as the program is being launched. Then, it will prompt the operator to insert/remove said system(s) at the appropriate times.
