[Te...] Posted February 4, 2019 Share Posted February 4, 2019 I just experienced an issue when creating a Base Alignment using Select Already Extracted Features. It is a part with a Plane for A, A OD circle for B and an ID circle for C. Normally I would just select A B C on the model and Calypso would populate the Alignment values as selected correctly. What it just did was populated the data incorrectly. Spatial - A Planar - B X - C Y - C Z - A Correct is: Spatial - A Planar - C (prefer a 3d line of the 2 circles even though it is only needed with Cylinders, do it the same way every time is my motto) X - B Y - B Z - A The order selected never was an issue, normally when I picked B second with this method it would set X and Y to B because B really isn't the planar rotation. It looks like you now have to select in the following order Spatial/Planar, the "good" news is that if I pick B first it doesn't use it as spatial but still fills in Planar, X, and Y incorrectly. If the secondary Datum doesn't stop rotation it is not the planar it is the origin it a axes. I have been seeing a lot of people struggling with alignments all of a sudden and I am wonder if this is the issue. Have we seen any warning or statement that Select Already Extracted Features works different. I did not notice this until the service pack. 6.6.12. Link to comment Share on other sites More sharing options...
[To...] Posted February 4, 2019 Share Posted February 4, 2019 I just tested it on 6.6.12 and it works just like you say it should. Are you able to repeat the process consistently? Link to comment Share on other sites More sharing options...
[Ri...] Posted February 4, 2019 Share Posted February 4, 2019 Calypso follows the Can/May/Must rule, so is it filling them in and abiding by that rule? I typically never let it auto fill the Base Alignment for me. I've just always manually filled it in, but I program differently than some, so yeah. Lol. Link to comment Share on other sites More sharing options...
[Te...] Posted February 4, 2019 Author Share Posted February 4, 2019 Found the issue...Funky CAD model. When I extract B, C gets extracted too. Because I did it as a circles I never noticed. No worries just a bad parasolid...and a reminder why I always ask for step. 😃 Link to comment Share on other sites More sharing options...
