GD&T Questions
Hey guys, hoping for someone smarter than me to help me out. I have this callout. How would you measure it? Would you just make a bunch of planes and then recall all of them later?
Also, this does mean that that the tolerance for the the 75x75 area is .09, but the entirety of the plane is 1.08, right?
Last question, the plane in question has a width that is less than 75. So do I just assume that I use all allowable width, then just cut the sections every 75 in the length?
Flatness.PNGFetching info...
For the first part you can use regular flatness, for the second part, you should be able to use Flatness Ref
It will determine the sections for you - the input parameters let you put in the info you need - if you hit F1 once you have the characteristic open it should explain it for you.
