Login Problems for some users - we are working on it ×
Changing from wire frame to solid CAD
So let me start off with I am new to calypso. I was using the help and wanted to change my CAD from a wire frame to a solid and help stated to hit the "render" icon. There is just one problem, I cannot find the render button. I am using Calypso 2018 ver.6.6.1200. Any help would be greatly appreciated. Never mind found it!!!
Thanks
Here is the button to select select solid body, circled in green.
For reasons unknown, sometimes you'll have to select the icons (from left) 2 and 3 at bottom to show model before slecting the solid icon.
Also, be sure to turn the bubble help on under the question mark at the top right menu so when you mouse over a icon it will define it.164_4d227f4729bf9a989cbaf2780c61e2d3.jpg
