[Me...] Posted February 1, 2019 Share Posted February 1, 2019 Need to apply Filter and Outlier or ???Flatness.PNG Link to comment https://qualityforum.zeiss.com/topic/19390-flatness/ Share on other sites More sharing options...
[Mi...] Posted February 1, 2019 Share Posted February 1, 2019 Yes. Anytime you scan a feature you need to filter out the scan. Well I do at least lol 😃 Link to comment https://qualityforum.zeiss.com/topic/19390-flatness/#findComment-109086 Share on other sites More sharing options...
[Na...] Posted February 1, 2019 Share Posted February 1, 2019 I would recommend anytime a feature is being scanned that filters and outliers are applied. As a rough guide, any scan with a closed loop path such as a complete circle path the Gaussian filter works great. Otherwise, if the loop or scan is not "closed", such as a line or an incomplete circle path, the spline filter is recommended. A simple rule of thumb for outliers is 3simga with 5 adjacent points with a pre-filter of 10-5000upr or 0-10mm depending on the feature in question. Link to comment https://qualityforum.zeiss.com/topic/19390-flatness/#findComment-109088 Share on other sites More sharing options...
