Measuring a part that is too tall - Lead to Hardware Endpoint error
Hi all,
I have a part that is too tall for the VAST XXT probe to rotate and travel. Its a Accura II Mass. what do you do to get around this. I've tried to block top edges and also decrease the z+ value for the clearance cube but no luck. The head still traveled to CPZ+ to change the RT POSITION after scanning a feature. I wanted it to just travel along the sides then rotate and finally scan the next feature. Thanks for any suggestion.
Go to Plan/ Navigation/ Rotate/Swivel Position and define where you want the swivel to occur. This will be global for the program so you may want to define Position Points within a feature strategy to clear the part and let it rotate.
Mark
