Model shifted after reopening program
I started a new program offline and had start the usual way: rotating part 180 degrees to correct orientation desired, making base alignment, making clearance plane then start making my features. Then, a few days later when I opened my program again, everything was there, except the model had been shifted from the its features and alignment. In the +y direction it moved by the length between my circle datum B and circle datum C, and shifted in the +z direction by half the thickness of the part.
I thought this was odd and decided to simply move the model the amount it was shifted. All the features where back in their place on the model and I continued programming on it, saved, and closed it.
I opened it today, and again the model has been shifted the same amount from its features, including the new features I added yesterday.
Anybody know why or how this is happening? 🙄
I suspect it has something to do of how I made the base alignment or/and the initial model rotation before programming it. ❓
https://qualityforum.zeiss.com/topic/19424-model-shifted-after-reopening-program/
