CAA with RDS and TP20
Just started a new job a few weeks ago. Up till now I have only used a Contura G2 with an XXT head. This place has a Spectrum machine with an RDS/TP20 set up. Is it possible to use CAA with this machine ?
Thanks
Steve
Nathan, I don't know that this is true, unless their is more information about the TP20 that I am unaware of. We have a Eclipse with the RDS TP20 and we don't have the option for CAA when we set up a probe. The TP20 is not used to scan so i don't think this is an option with the TP20.
The newer RDS (Rotating Digital Sensor) Probe Heads are almost always shipped with the capability of the RC-CAA qualification. There are probably a few systems with what I would call, 1st or 2nd Generation RDS Probe Heads. ZEISS has typically put decals on the end of the sensor in red letters to signify that it is an RDS-CAA equipped sensor.
If it's not obvious, decals wear off, then try creating a new stylus system. When the window opens to name it, there will be a small check box that allows the user to activate RDS-CAA.
