[Ra...] Posted January 15, 2019 Share Posted January 15, 2019 I finally figured out a way to write a program to calibrate all of the probes in the rack, but is there a way to report the results when it is done. Thanks, Rachel Link to comment Share on other sites More sharing options...
[Th...] Posted January 15, 2019 Share Posted January 15, 2019 Hello Rachel, if you use the standard calibration function of Calypso, just use the Default printout. You have to start this one manually because the CNC start menu does not show it. Otherwise, you can start the measurement without ANY printouts and plots activated. At the end, you will get your calibration protocol automatically. I hope this helps. Link to comment Share on other sites More sharing options...
[To...] Posted January 15, 2019 Share Posted January 15, 2019 Please sign in to view this quote. Also, if you activate "Save to PDF", it will generate a pdf of the default print out, Link to comment Share on other sites More sharing options...
[Cl...] Posted January 15, 2019 Share Posted January 15, 2019 You can also create the attached result element that will output the sigma value. 1 Link to comment Share on other sites More sharing options...
[Te...] Posted January 16, 2019 Share Posted January 16, 2019 This should help tooProbe Qualification Program 2018.pdf 2 Link to comment Share on other sites More sharing options...
[Mi...] Posted January 17, 2019 Share Posted January 17, 2019 Those are some REALLY nice write ups there Mr. Ted. Where were you 9 yrs ago LMAO Great job as I am positive it helps the new guys out. 🤠 🤠 Link to comment Share on other sites More sharing options...
[Su...] Posted January 21, 2019 Share Posted January 21, 2019 Hello sir, Your explanations with pdf attachment was awesome,and I want to know one topic on "programmable stop" .how it's used in program. Link to comment Share on other sites More sharing options...
[Cl...] Posted January 21, 2019 Share Posted January 21, 2019 This is just one of many uses for the programmable stop. Say you have a program where the operator has to remove, or install a flex plug. Insert a programmable stop (with a position point) in the feature before the feature measuring the flex plug. Here you can instruct the operator to install, or replace it. Link to comment Share on other sites More sharing options...
[Lu...] Posted 22 hours ago Share Posted 22 hours ago how mutch sigma value we can have to have a aceptable stylus, i had a small colision withh a D6L100 stylus with the body carbon fiber i had previous sigma values before colision 0.0002, afte rcolision i have values between 0.0008 to 0.0014 depending of the angular position. Anyone can help me ? Link to comment Share on other sites More sharing options...
[Ca...] Posted 21 hours ago Share Posted 21 hours ago Hi Luis - What type of stylus is it and what type of qualification are you using? Typically for most standard stylus, I would recommend not exceeding 0.001mm sigma. However, CAA qualifications or long skinny stylus could exceed that and be just fine. Since it is following a collision, I may recommend running some tests on known parts or gages to ensure that everything is measuring normally rather than relying solely on the sigma numbers. Link to comment Share on other sites More sharing options...
[Lu...] Posted 1 hour ago Share Posted 1 hour ago (edited) Hi Caitlin, Im using this stylus D6L100 with carbon fiber shaft. For the calibration im using the qualify passive stylus (scanning calibration) I will run some tests with ring gauge to make sure the stylus is still good, but the sigma values from 0.0001/0.0002 to 0.0008 to 0.0014 are concerning me Edited 1 hour ago Link to comment Share on other sites More sharing options...
