Error code problem
Hello Genny,
I'm not familiar with that error code, but I can give some tips for installing:
1. When you download the installation file choose 'save'
2. Make sure you have full administrator privileges for the installation
3. Disable antivirus
4. Make sure your computer meets the system requirements (these are listed when you run the setup.exe, before you begin the install.)
5. Remember with PiWeb SBS/Enterprise you shouldn't install a client with a higher version than the server.
If you follow these most common solutions, the installation should go smoothly.
