[Da...] Posted December 7, 2018 Share Posted December 7, 2018 Hi, I have a plastic part which comes bended out of molding tool. How to approach this? I have curve, I haven't tried to measure yet, but I expect problem. If I do section, the nominal points for the curve would be on the same height, which isn't the case on the part. Attachments (units are in mm): drawing, CAD model, another CAD, which represents the real world situation Capture.PNGFetching info... groove-pic.PNGFetching info... groove-bended-pic.PNGFetching info... Capture.PNGFetching info... groove-step.zipFetching info... groove-sat.zipFetching info... Link to comment Share on other sites More sharing options...
[Me...] Posted December 7, 2018 Share Posted December 7, 2018 A 3D view of the part would be helpful. Can't download your files due to security issues. Can you section, create the curve, and then transform it to the location you want? Just grabbing at straws here since what you're trying to do is unclear to me. Link to comment Share on other sites More sharing options...
[Da...] Posted December 7, 2018 Author Share Posted December 7, 2018 Please sign in to view this quote. Updated. Link to comment Share on other sites More sharing options...
[Me...] Posted December 7, 2018 Share Posted December 7, 2018 If your part is warped after molding then you either need to restrain it, if allowed per the customer/print, and check it per the print, or if not acceptable to restrain the part, check it as it is. The nominals are what they are. The section shown is a perpendicular cut across the slot. It is what it is. You could scan it as an unknown contour and best fit it to the model, but again, it is what it is, and the nominal are what they are.It really comes down to what I acceptable to the customer. Link to comment Share on other sites More sharing options...
[Da...] Posted January 18, 2019 Author Share Posted January 18, 2019 Updated with one more screenshot, section with 2d curve Link to comment Share on other sites More sharing options...
[Cl...] Posted January 18, 2019 Share Posted January 18, 2019 I just picked space points on a bent surface on one of my models and recalled them into a 2d curve, Then turned on digitizing under Nominal Data, and it scanned. I don't know how it will work for you, or what kind of result you'll get? Might be worth a try? Link to comment Share on other sites More sharing options...
[Da...] Posted January 18, 2019 Author Share Posted January 18, 2019 Thanks Clarke, please share a printscreen, where is "digitizing under nominal data"? Link to comment Share on other sites More sharing options...
[Cl...] Posted January 18, 2019 Share Posted January 18, 2019 Here you go . Link to comment Share on other sites More sharing options...
[Re...] Posted January 18, 2019 Share Posted January 18, 2019 You can do a section of the model with a cylinder to create the 3d-curve !! Link to comment Share on other sites More sharing options...
[Da...] Posted January 18, 2019 Author Share Posted January 18, 2019 Also great idea Reiner, thank you! Link to comment Share on other sites More sharing options...
