How to automatically report min/max points on 2D profile?
Something I've noticed is missing from PiWeb's large plots are the minimum and maximum deviation values on a 2D curve. I know you can pick those points from within Monitor to see their values, but we don't use the interactive functionality and we're not set up to (all our reports are just saved to PDF). Is there a way to add that info back onto the page somewhere? The old Graphics Element characteristics gave us those numbers, and it seemed like good reference info to have on an otherwise non-interactive printout.
I think that this could be added to the report.
If you use the Curve Form Characteristic. On the PiWeb Report, it will show the absolute maximum deviation with direction, just not both.
I suppose it doesn't have to be on the plot itself. Can those deviation values be pulled into result elements? I could report them on the printout instead.
Are the max/min values not on the plot by default? There should be 2 circles on the plot and then the values for those at the bottom of the plat I believe. Not 100% sure if the 2d profile works like that but must of the other plots do.
Post edit: I figured out how to get formulas out of the menu in Result Element, so the question that was here no longer applies.
Thanks for the help! This pretty much solves my problem.
