lost my zero?
hey guys. Today I was working on an old job that I really hated the way it was done. I deleted a bunch of stuff and rewrote it the way I wanted it to be. Everything looked good. There was a start alignment that everyone basically hated so I deleted it and turned off the start alignment. Now when I do the manual run the points are showing up way off the part and when I try to do a cnc run, it travels way off the part and faults. Is the program corrupt or is there a way to fix this?
https://qualityforum.zeiss.com/topic/19526-lost-my-zero/
dang, I get the feeling I'm talking to myself again, LOL! Ok, I dumped the old program and created a new one, or am creating a new on. Imported the step file and started setting it all up and I get a message when I pick a surface stating that the "normal vector will be inverted". I've never seen this note before. Could this be causing the problem? Is it a problem? It doesn't happen on any other files... I don't think? Maybe there's a problem in the model?
https://qualityforum.zeiss.com/topic/19526-lost-my-zero/#findComment-109708
In the beginning you wrote it is an old job. Was it also made with an old version of calypso?
Years ago I altered a program from version 4 without first porting it to 5. In the following test the machine ran really weird ways in the air, but not on the part where it should.
Sometimes when modifying a program it is needed to run it once before. Then the system knows all the coordinates it needs. Yes, it takes some time but it is relatively safe if you are not using a 3D model.
https://qualityforum.zeiss.com/topic/19526-lost-my-zero/#findComment-109710
It's been run and saved in the present updated version several times. I decided it was in some way corrupted and dumped it and started with a new measurement plan. That's when I started getting this new warning. I wondered if the model was somehow to blame originally and my new edits finally triggered something. eh, grasping at straws...
https://qualityforum.zeiss.com/topic/19526-lost-my-zero/#findComment-109712
I have seen this pop up on my cad model at times. Now for ME It did not change anything I was working on. I asked in the old forum about the inverted message, but I cant remember what I was told. CRS 🙄
But again for ME it changed nothing at all. It was business as usual.
https://qualityforum.zeiss.com/topic/19526-lost-my-zero/#findComment-109714
yeah, I just found a thread that asks about it. I'm thinking it's the model. I opened the stp file in Solidworks and was going to eliminate any of the unnecessary junk in it like hardware and kintex and double walls but the file was kinda big and got pretty laggy. after it crashed on me I gave up on it. It seems to be working ok so I'll give it a test one of these days and see if it's ok.
One thing I noticed on the original program. When I opened it in simulation, the probe was messed up. It was apart and some pieces were backwards??? On the new program it is fine.
https://qualityforum.zeiss.com/topic/19526-lost-my-zero/#findComment-109716
