Plus/Minus .0002?
We have a new job heading our way, high volume, very tight
tolerances of some of the dimensions ± .0002 on one diameter.
Can my Contura (XXT/RDS/TL1) handle that?
I'm unsure of the size of your machine, but a new Contura 7/7/6 - 7/10/6 with the XXT is spec'd at 1.7 microns. That puts you at more than 10% of your tolerance.
You can probably get close, but realistically you either need a tighter spec machine or a different measuring device (laser micrometer).
Oh. Depending on this size of your parts, maybe a Micura would work. They make a 5/7/5 size now with the same spec.
That was kind of a rhetorical question. I recommended a laser micrometer for the diameter in question.
One concern I have is that the quality lab where this CMM is located isn't temperature controlled very
well. I'm not sure how 17-4 material is going to react in that environment?
Personally not a big fan of laser mics.
are you dealing with OD or ID diameter?
We had a Sunnen air gage at my last shop for .0002 total tol ID, those gages were great!
Laser-Mics are great if used and setup properly. A lot of issues arise from not being properly fixtured.
Air-gages are great, Edmunds make a great setup.
If the environment isn't great for both the manufacturing or measurement, you are going to be chasing your tail.
Thermal expansion co-efficient (@ 21-93°C/69.8-199°F) 10.8 µm/m°C 6.00 µin/in°F
