How does Best Fit True Position work?
In my example, there are two diameters in the composite FCF
The upper = .003(m) to C_A_B
The lower = .0005(m)_C
Datum C is the surface the diameters exist in.
In the lower segment, how is the Modifier applied when utilizing Best Fit?
Is the Modifier applied from each diameter allowing movement?
Do the features shift pertaining to the results of the upper segment?
The top on is controlling the location of the pattern (ABC) NO translation or rotation allowed
The Lower on is controlling the pattern to itself (C) translation and rotation allowed
