[Pi...] Posted April 29, 2021 Share Posted April 29, 2021 Hi! I use a space mouse device, but i have problem with configuration. Is it possible to set 3D views from ATOS with a space mouse button? Regards, Piotr Link to comment https://qualityforum.zeiss.com/topic/196-3dconnexion-space-mouse-configuration/ Share on other sites More sharing options...
[Na...] Posted April 30, 2021 Share Posted April 30, 2021 Hi, you can define shortcuts under View -> Screen Setup -> Shortcuts for an item in the menu, e.g. View -> Standard ISO view. The shortcut key would be a button on your space mouse then. Regards, Nanno Link to comment https://qualityforum.zeiss.com/topic/196-3dconnexion-space-mouse-configuration/#findComment-567 Share on other sites More sharing options...
