Automatic healing CAD model
I healed the model for a part with gear teeth. I've used the "Build Geometry" option for years now but I noticed it created a small step on the gear teeth for my curve for some reason...It has me questioning using this option going forward.
What is recommended for healing the model without making changes to it?
Shawn,
The help files recommends Correct boundary curves setting. "Gaps in the boundary curves of surfaces and sections which are not exactly aligned are corrected.
We recommend this setting as, in most cases, it is sufficient for a successful healing. " It also takes less time for large models.
I use this setting all the time without any problems. HTH
